C3D 2017 DATA SHORTCUTS ANNOTATION LABELS DISAPPEARING
Joe-Bouza
Mentor Mentor
Message 1 of 50
Joe-Bouza
@BushW,  This is URGENT
There is something wrong and I dont know why or what is causing it but I an running out of time to doing this.
sheet files Data short cut
Surfaces, alignments, profiles and drainage and I annotated in the sheet files. come back later and it all gone! all the object are in the file
WTH is this?
the screen cast shows an inconsistency in the data shortcut node and the data shortcut editor.
http://autode.sk/2z3mM4s
Enhanced reference audit problems for database "O:\CE338A-02 flower fields subdivision map\DESIGN\ROAD B PLAN & PROFILE.bak2.DWG"
(in the form: "Name, Reason, Repair Method"):
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [202A14C], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [202A152], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [202A158], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [202A15E], Broken reference, Remove
AECC_VALIGNMENT_CRESTCURVE_LABEL_GROUP [202A164], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A149], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A14D], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A14F], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A153], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A155], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A159], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A15B], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A15F], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A161], Broken reference, Remove
AECC_VALIGNMENT_LINE_LABEL_GROUP [202A165], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [202A14A], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [202A150], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [202A156], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [202A15C], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [202A162], Broken reference, Remove
AECC_VALIGNMENT_PVI_LABEL_GROUP [202A2FA], Broken reference, Remove
AECC_VALIGNMENT_SAGCURVE_LABEL_GROUP [202A14B], Broken reference, Remove
AECC_VALIGNMENT_SAGCURVE_LABEL_GROUP [202A151], Broken reference, Remove
AECC_VALIGNMENT_SAGCURVE_LABEL_GROUP [202A157], Broken reference, Remove
AECC_VALIGNMENT_SAGCURVE_LABEL_GROUP [202A15D], Broken reference, Remove
AECC_VALIGNMENT_SAGCURVE_LABEL_GROUP [202A163], Broken reference, RemovePress ENTER to continue:
@BushW has edited your subject line for clarity: DATA SHORTCUTS ARE HOSED AND MY ANNOTATION KEEPS DISAPEARING
Joe Bouza
Replies (49)
Message 2 of 50
BushW
Hello @Joe-Bouza
Not sure why this is happening but, it looks like you have some broken data shortcut links. Did anything change with the source files pathing or naming?
Take a look at <<blog>> and AKN article "In Search of the Missing Link" - Repairing Civil 3D Data Shortcuts. to see this can help you with repairing the missing links.
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 3 of 50
BushW
Hello @Joe-Bouza
I was following up here, any progress on this issue? Did you get the opportunity to review AKN article and blog post to see that helped with your problem?
Wendell
Wendell Bush
Message 4 of 50
Joe-Bouza
Thanks for the followup Wendal
Not quite the same thing. Nothing has been renamed. I'm very concerned with the inconsistency of the shortcut folder contents in the DS editor vs the DS node
Joe Bouza
Message 5 of 50
BushW
Hello @Joe-Bouza
Can you share this project so, we can take a look at it. I can send you a link to upload the project for review.
Wendell
Wendell Bush
Message 6 of 50
Joe-Bouza
I can do that
Joe Bouza
Message 7 of 50
BushW
Hi @Joe-Bouza
I just sent you a link to upload your project.
Wendell
Wendell Bush
Message 8 of 50
CivilFlow
Hi Joe-
Just curious if you get the same error in drawings that have some of these Project data shortcuts referenced in?  If so, do you see links show up via the Data Shortcut Manager interface under Manage Tab\Manage Data Shortcuts?
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 9 of 50
Joe-Bouza
Hi Wendell
I'm making the etransmit now. I had been out of office
Joe Bouza
Message 10 of 50
Joe-Bouza
Hi Mike
Hard to say at this time. But I can say that the DS editor shows nothing and the DS node shows everything
Joe Bouza
Message 11 of 50
Joe-Bouza
Hi Wendell
It has been uploaded.
Joe Bouza
Message 12 of 50
BushW
Hello @Joe-Bouza
I got the project data, and I will review it and get back to you no later than Wednesday.
Wendell
Wendell Bush
Message 13 of 50
BushW
Hello @Joe-Bouza
I just wanted to let you know that I'm still reviewing this issue with my team members. I will post back by the end of the week on this matter.
Wendell
Wendell Bush
Message 14 of 50
BushW
Hello @Joe-Bouza
I have no answer why this happened but, did you have ??? were the annotated labels were? Because if so, you can use the DATA Shortcut Manager to repair broken data shortcuts references to hopeful restore those broken data shortcuts. The command is MANAGEDATASHORTCUTS.
Hopefully, this will help solve the problem.
Wendell Bush
Message 15 of 50
Joe-Bouza
Hi Wendell @BushW
No. I wish I did then I could recover as you describe. So far I have used a belt ans suspender approach and associate the drawing with the current project and things have no gone wonky.
Did you and the team happen to explore the discrepancy in the content of data short cut node in the prospector  versus what gets listed in the data shortcut editor?
Joe Bouza
Message 16 of 50
Joe-Bouza
@BushWJust happened again different project! I think this has to escalate up the ladder
Enhanced reference audit problems for database "O:\CE2682- CR-1\DESIGN\CE2682-00-G-GA-001.dwg"
AECC_GENERAL_SEGMENT_LABEL [909012D], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [90930FE], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [90930FF], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFA1], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFA2], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFA3], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFA4], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFA7], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFA8], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFA9], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFAA], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFAB], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFAC], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFAD], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFAE], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFAF], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB0], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB1], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB2], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB3], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB4], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB5], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB6], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB7], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB8], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFB9], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFBA], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFBB], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFBC], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFBD], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFBE], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFBF], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC0], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC1], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC2], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC3], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC4], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC5], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC6], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC7], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC8], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFC9], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFCA], Broken reference, Remove
AECC_GENERAL_SEGMENT_LABEL [909AFCB], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6C7], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6C9], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6CA], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6CB], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6CC], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6CD], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6CE], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6CF], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D0], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D1], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D2], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D3], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D4], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D5], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D6], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D7], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D8], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6D9], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6DA], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6DB], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6DC], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6DD], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6DE], Broken reference, Remove
AECC_STRUCTURE_LABEL [5E6DF], Broken reference, Remove
Joe Bouza
Message 17 of 50
AllenJessup
Joe, You list 2014 & 2015 in your signature. What release are you doing this project in? If it's happening in more than one project. You might want to do a repair or reinstall of that version.
Allen Jessup
CAD Manager - Designer
Message 18 of 50
Joe-Bouza
sorry 2017
this is straight forward stuff: Sheet file with xref base and ds added and labeled then the labels disappear yet all the DS are present and unbroken
Joe Bouza
Message 19 of 50
Joe-Bouza
I forget where to edit my signature? Its not under edit profile
Joe Bouza
Message 20 of 50
AllenJessup
It's on the Personal Tab.
Easiest way to get there is to follow the breadcrumbs in the upper right.
Allen Jessup
