C3D 2016 - Pressure Pipe Inner Diameter Issue
Here's a strange one that is very problematic. I was in the middle of editing a pressure network by drawing pipes. All of a sudden the last 10" PVC pipe I went to create had the label show the size as 11". I deleted the pipe, re-created it and the same thing happened. So I checked the pipes I had just created before this and they all were correct. The next thing to check was the parts list, which now has incorrect inner diameters for ALL pressure pipes. This isn't limited to just a single parts list, either. Every parts list in C3D has an incorrect inner diameter that is the same or larger than the outside diameter. This is happening to multiple pipe materials and even different drawings.
I have a screenshot that shows both the catalog properties as well as the 10" PVC pipe properties from the parts list in C3D. You can clearly see that the Diameter Inside (in) column in the Content Catalog Editor shows the size as 10, but in C3D the part shows the Inner Diameter the same as the Outer Diameter.
Here is another one showing the 12" ductile iron pipe having it's inner diameter larger than the outer diameter and doesn't match the catalog.
This happened in the middle of me editing a pressure pipe network. The pressure catalog has not even been edited in over four weeks. I've closed the drawing, closed C3D, and even restarted the workstation. None of those have fixed this issue. What the heck is going on? I really need to get this working again as we've got a deadline coming up for a multi-billion dollar project.
Windows 11
32GB RAM
