I think I found bug in TIN volume surface. I made video and attached it.
I have two TIN surfaces. One big and one smaller. I made TIN volume surface from them and got TIN volume surface only where they intersect. Made data shortcut to TIN volume surface and promoted it to other drawing. Then I added boundary to TIN surface bigger then the surface, but surface not only got cut to boundary, but got extended beyond it's possible boundary. Where here should not be any TIN surface and here it took values from bigger TIN surface it was made from.
I think TIN volume surface should not save data from it's one parent surface if here are no second parent surface because it will not be volume data. And I think TIN surface should not keep hidden data (beyond outer boundary or inside hide boundary) then doing promote, because boundaries are not promoted.
Now TIN surface keeps more data after promote then it needs and have wrong data too. TIN volume surface (thickness surface) have data about elevation.
