Block reference scale too big
met1ns
met1ns
Hello.
So I got this drawing (attached) with measured points in two different locations. However the block references scale is too high. I have tried everything I know of, units, -dwgunits etc but without result. I cant manage to make the blocks smaller.
Anyone that can take a look and please tell me step by step how you managed to scale it down? Because Im sure someone will. Units should be set to decimal and meters. I live in EU and use civil 3d 2019.
Help is much preciated.
Thank you
jefflambert9091
Check your insunits. If in meters should be a setting of 6. When you insert your drawing, pay attention to the bottom right.  "block Unit" in the insert window. Its reading in the inserted drawing and reads you insunits. I set mine to 0 witch is unitless. That way you control the scale.
Jeff
Civil 3D 2024
met1ns
Hello Jeff,
Thanks for your answer. However it's already on 6.
Are you able to open the attached drawing and get the scaling correct?
jefflambert9091
I tested it before I posted. It worked for me when I had my insunits on unitless and when on 6. Hummmm… I will think some more.....
Jeff
Civil 3D 2024
jefflambert9091
I re-read your post. Are you just trying to get the Stake Flag block smaller? If so, just righ click on it, open it up in the block editor and scale the entities down to what you want. Make sure you identify block insertion point and scale from there.
Jeff
Civil 3D 2024
met1ns
Thank you Jeff.
This is what I had to go with.
