Summary:
I am experiencing extreme difficulty inserting blocks into drawings -- block previews are NOT displaying in the BLOCKS palette; sometimes they display in the Insert > [Block tab] Insert menu from the ribbon, sometimes they do not. It is extremely frustrating and I am losing time over it.
Civil3D 2021 / Windows 10 Pro (64bit)
Here is what I am seeing in the BLOCKS palette:
In this drawing, I do not see block previews either when (via the ribbon), I select [Insert Tab] > [Block panel] Insert, however, within the past day, there have been some drawings where the BLOCKS palette previews are non-existent, but the Insert > [Block]Insert pull down menu shows block previews.
Of note, when I open a new drawing (e.g. Qnew), the blocks are properly previewed in both the BLOCKS palette and the [Insert] > [Blocks]Insert drop down menu.
This is a recent C3D 2021 install from scratch on a computer with a fresh install of Windows 10 Pro. The "problem" drawing may be an older .dwg file from an earlier install of C3D 2019 that has been SAVE AS'd multiple times.
I have audited the .dwg several times. No effect. I have saved all drawings, exited, restarted C3D and the problem remains.
What gives? This is a real PITA.
