Bind/Insert vs WBLOCK
pbradburyYWE5N
pbradburyYWE5N
I have quickly searched online but am unable to find what the difference is between these two operations. It would certainly appear that Insert is the same/similar as WBLOCK, but I am not sure, especially as it concerns copying survey figures and cogo points from one file to another..
brian.strandberg
XREF Bind / Insert will take an xref and remove the association to an external file and place it directly in your drawing.
WBLOCK is a completely different thing, where you take content that is in your drawing that you select and write it to an external drawing file.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Neilw_05
wblock is for writing out selected entities to a new file. Bind/Insert is for bringing external content into a drawing via XREF. In that regard they are not the same at all. Could you clarify your question?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
neilyj666
WBLOCK is also very useful in writing out a "problematic" file to a new clean one
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
pbradburyYWE5N
Guess I didn't clarify my question enough.. If your purpose is to copy linework from one drawing into another one, what process is best, bind/insert or WBLOCK and insert that block into another drawing? I come originally from Microstation background and there is one process to copy in linework from one drawing to another, not sure why AutoCAD has so many different ways of doing this.. There is also CNTRL-C, and paste to original coordinates..
