Best Practice for Corridor surface builds
RobertEVs
Advisor Advisor
RobertEVs
At times in the past, I have generated my corridor surface FG then later went into its edits and added breaklines, swap edges, paste some other surface, added hide boundary, etc. It never turns out good down the road but it's too late with as many edits as it might have in its build.
These days I like to create my corridor FG and that surface is done! I create another new container FG, paste in my corridor FG then any EDITS needed are done in that surface container.
How do you C3D'rs do surfaces when using corridor(s)?
neilyj666
I tend to set the triangle angle constraint (to typically 105°) and the triangle length to an appropriate  length (typically around 10m) as this usually produces a decent surface for my purposes. I will generally work with one corridor comprising multiple baselines so only one finished and one formation surface to manage.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Joe-Bouza
I suggest never add edit to the corridor surface directly. Use a composite to add data
Joe Bouza
