Batch Export Civil3D to AutoCAD
cameron.robertsXX8LX
303 次查看
1 条回复
1 条消息(共 2 条)
Does anybody know a way to batch export civil3d drawings to autocad and be able to delete the layout tabs associated with the drawings?
Any help you can provide would be much appreciated!
0 个赞
304 次查看
1 条回复
回复 (1)
2 条消息(共 2 条)
samir.rezk
Autodesk Support
Autodesk Support
Hi @cameron.robertsXX8LX
It is possible to write an AutoCAD Script (SCR) file to delete the layouts and export the model to AutoCAD via command line. Once we have an SCR file created The Autodesk Batch Save Utility (installed with Civil 3D) may be used to run the script on as many drawing files as needed.
Probably an easier option is right on the Output Ribbon tab > Export panel > EXPORTC3DDRAWING Command, the command is able to export multiple Civil 3D drawings in a Folder with an option to not include Sheets.
Hope this helps,
Samir Rezk
Technical Support Specialist
0 个赞
