Your picture is of the assembly that you are using.
I think that you are trying to use this as an illustration of the "Typical Section."
If this is the case, it can not be done.
The assembly is a schemaric diagram that is intended to help the designer visualize the cross section. It looks like a typical section, but that is not its intent.
You will need a workaround.
Try creating a dummy alignment, dummy profile (level) and dummy surface. The surface should cover all of the Typical conditions. You can then assign sections and create section views. The sections views will become your typical sections. You may want to"stack" some of the section views to show more than one condition in the view. Annotate the section views as needed.
Christopher Stevens
