AWOL GRADING BETWEEN BUILDING PADS
Can anybody explain what is going on here? I have been experiencing odd results grading between objects in a new project that I have been unable to eliminate. The combinations and permutations as to what might be causing these errors seems to be fairly daunting so I have gone back to the basics and set up a new drawing using an existing survey and placing a number of arbitrary Polyline Rectangles in it to see if I can't tease out where I am going wrong [I am relatively new to CIVIL3D]
Trial Work Flow:-
1] Convert Rectangle 1 Top LHS to a Feature Line. Assign Site Elevation [Flat Pad] and Grading Group
2] Apply a 3:1 Daylight criteria to external edges of Rectangle.
3] Apply 'infill' to interior of Rectangle 1
4] Repeat for Rectangle 2 Top RHS.
Result:- Image 1
5] Repeat the above for Rectangle 3 MID LHS
Result:- Image 2
I also attach Image 3 which was a previous attempt using the above Work Flow BUT without applying an 'INFILL' to the Rectangles.
NOTE:- I have also carried out the same Work Flow with two side by side Rectangles [as per Rectangle 1 and 2] but where the 'Fill' slopes overlap. CIVIL3D simply adjusted the original 'Fill' slope of Rectangle 1 to incorporate the 'Fill' slope of Rectangle 2 when the 3:1 Daylight criteria were applied to it.
Questions:
A] If grading merges 'Side to Side' then why not 'Top to Bottom' Is it because one is a 'Cut' and the other a 'Fill' slope? Would not have thought so given that the Daylight criteria works for both Cut and Fill?
B] Should I place Rectangle [3 Mid LHS] in a different Site and then merge the two sites?
c] Should Rectangle 3 it be in a different Grading Group?
I appreciate all this must be very basic but I am clearly not grasping the correct Work Flow for multiple Grading Objects at what is surely a comparatively simple level.
