Automatic Vehicle block in assembly and secction view
gustavo_bergoya1
Message 1 of 22
gustavo_bergoya1
In Subassembly Composer I created a subassembly that shows the type of vehicle in the road lane. It has the parametric code that can be changed in Civil 3D.
Here I applied a fixed scale
Regards
Replies (21)
Message 21 of 22
melantonuky
in the circle or curve area, the assembly code does not work, the same bench elevation is not connected properly
code string at the point in the sub assembly has been entered but still does not work
Message 22 of 22
melantonuky
This sub assembly file works on straight road alignments only, when the road alignment is circle and curve, the slope corridor is not formed according to the existing elevation.
