Automatic Vehicle block in assembly and secction view
gustavo_bergoya1
Message 1 of 22
gustavo_bergoya1
In Subassembly Composer I created a subassembly that shows the type of vehicle in the road lane. It has the parametric code that can be changed in Civil 3D.
Here I applied a fixed scale
Regards
Replies (21)
Message 2 of 22
KMercier_C3D
That is a neat idea. Did you have a question, or just wanted to show that it can be done?
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Message 3 of 22
gustavo_bergoya1
I just wanted to show what can be done.
Message 4 of 22
melantonuky
Please share it sir
Message 5 of 22
nkiakas
Nice and interesting
Message 6 of 22
melantonuky
please share the turorial sir
Message 7 of 22
gustavo_bergoya1
Use link code and the right and left side:
Car_front
Car_back
Bus_front
Bus_back
Truck_front
truck_back
SUV_front
SUV_back
Check the description for this codes on properties
Use my template for this
Message 8 of 22
melantonuky
Gracias sir
Message 9 of 22
nkiakas
Hi @gustavo_bergoya1
So, the user, adds in then subassembly properties, in the top link, the code for the vehicle type and the side (front or back)
In C3D there are predefined link labels, according to the user input code above.
Each link label "calls" a block according to the vehicle type + type that matches with the use input codes.
Does it work like this or i understood wrong?
Regards
Message 10 of 22
melantonuky
How to connect point codes with the same elevation?
is there a specific code string or another way?
Message 11 of 22
gustavo_bergoya1
Do you need create this in subassembly composer.
I send you a subassembly example for this.
Message 12 of 22
melantonuky
Thank You Sir
Message 13 of 22
Jeew-m
Good Work.
I remember I did a similar thing sometime back to add a barrier through the available subassemblies in Civil 3D.
[video]
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 14 of 22
melantonuky
I am making a road in a hilly area, I want to make horizontal benches with zero percent slope. The road profile is steep but I don't want daylight benches to follow the road gradient.
for example: Like shown in this dwg file, Road is going down but daylight benches has a specific level.
Message 15 of 22
melantonuky
this is the file
Message 16 of 22
melantonuky
this is the .pkt file
Message 17 of 22
nkiakas
Hi @melantonuky
Let say that your road is the red line (in a profile view).
No your benches are like the green lines.
You want your benches to follow the blue lines.
Is this what you want to do?
Regards
Message 18 of 22
melantonuky
Message 19 of 22
melantonuky
in the vertical alignment, its work, but in the circle or curve, the code string doesnt work
Message 20 of 22
melantonuky
