automatic section labels
chris_tulloch
chris_tulloch
Good Morning,
Not sure if this is possible, but is there a way to create a label (circled in red) automatically showing the cut dimension? This needs to be done every 100 meters say for 60 Km. No, we will not be placing that label manually.
andrewpuller3811
Yes you can do it using a link label style and assign it to the corresponding link in your code set style.
Attached is an example to get you started.
The link label style named "VerticalDimLabel" produces a vertical distance label similar to a dimension label
It uses one construction line that is not visible, and from that defines the lines that make up the visible label lines.
The label style uses 3 expressions, "ElevChange" to calculate the vertical height difference for the text, "NegDeltaHeight" to set the height of the vertical line length and "DimHozOffset" to set the distance the the vertical line is offset from the end of the link.
Have a look and modify the style to suit you exact requirements.
To add the arrows, just add a block into the style and attach it to the horizontal dimension line. You will need one at the start of the line and one at the end of the line.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
chris_tulloch
thank you very much! 🙂
