Autodesk Vehicle Tracking Library
christian_leonardo78H8F
Does anyone know if the Autodesk Vehicle Tracking (AVT) have custom vehicles/libraries for wind farm transport vehicles ? Or how to download it ?
Christian
ianjchap
Hi @christian_leonardo78H8F
Check through all the library to make sure, but I've not come across that vehicle.
You can however create a custom vehicle if you have all the relevant manufacturer details. Some more info here:-
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Creating-Additiona...
https://help.autodesk.com/view/VEHTRK/2024/ENU/?guid=GUID-0768B9B4-2A23-40DC-ABB4-FAED3440EE1E
I think you'll also find some useful guidance in the Vehicle Tracking help section of the software.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
neilyj666
There some ones of limited use - mainly for a clamp tower trailer
In my experience the blade transporter is more critical and I have had to create my own over the years as blades have increased in size. However, unless you actually work for a blade transportation company, you will not get all the required data to create these vehicle accurately so there is a bit educated guesswork needed.
I also find that the interface for vehicle modification and adding bodies, loads etc is a bit clunky and not a particularly pleasant user experience
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
