Autodesk SSA - What SWMM 5 Version (5.0.013?)???
Message 1 of 15
What version of SWMM 5 is Autodesk SSA running?
My guess is 5.0.013? Even with SSA 2016.
Does anyone know of the last update? I know that LID controls have not yet been included (SWMM 5.1).
I am trying to match SSA with PCSWMM and 5.0.013 appears to match, but not any of the later updates...
Conrad
Replies (14)
Message 2 of 15
Matt.Anderson
SSA should match 5.0.21 or 22, with the exception of new elements introduced from about 5.0.13 on.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 3 of 15
Do you mean that it uses that version of SWMM for both the hydrologic runoff calculations, AND the hydrodynamic hydraulic routing calculations?
Message 4 of 15
Charlie.Ogden
Yes, SSA is using the SWMM 5.0.021 engine for the EPA SWMM hydrology method and for the routing methods and other components... but the LID treatment units in particular have not been added in.
Charlie Ogden, PE
Product Manager
Message 5 of 15
Thank you for clarifying that!
Message 6 of 15
jmayo-EE
Any change to this? Was SSA updated to the 5.1.013 engine? I am getting different results in SSA2019 and 5.1.013.
John Mayo
Message 7 of 15
jmayo-EE
Issue I have right now is with the hydrology.
SSA
Subbasin             Total     Total     Total     Total     Total      Peak       Runoff        Time of
  ID                Rainfall     Runon     Evap.    Infil.    Runoff    Runoff  Coefficient  Concentration
                          in        in        in        in        in       cfs              days  hh:mm:ss
  AREA 01               8.30      0.00      0.00      0.00      8.11      4.59        0.977    0  02:01:28
  AREA 02               8.30      0.00      0.00      0.00      8.28     10.49        0.998    0  00:13:56
  AREA 03               8.30      0.00      0.00      0.00      8.21      2.89        0.990    0  00:50:57
SWMM 5.1.013
        Pk
Subcatchment     in         in         in         in         in         in         in         10^6 gal   CFS        Coeff
AREA01           8.30       0.00       0.00       0.00       3.33       4.80       8.13       0.22       5.21       0.979
AREA02           8.30       0.00       0.00       0.00       8.33       0.00       8.33       0.34       13.37      1.004
AREA03           8.30       0.00       0.00       0.00       2.13       6.15       8.28       0.11       3.39       0.997
John Mayo
Message 8 of 15
Matt.Anderson
Highly unlikely.   There have been a bunch of 5.1 changes, including getting to 5.1.013.
We are about to release the next build of InfoSWMM with the 5.1.013 engine which was a lot of work and we keep the engine update.
Product Manager
Autodesk (Innovyze)
Message 9 of 15
Matt.Anderson
John -
Remember - SSA 2019 was released last year in March/May time frame.   EPA released SWMM5.1.013 in September 2018.
Short of time travel - impossible for 2019 to have been future proofed.
I should note that "we" in the prior reply is Innovyze.
Product Manager
Autodesk (Innovyze)
Message 10 of 15
jmayo-EE
I didn't mean to come across as snarky Matt. It is just an inquiry. This is my first look at the EPA app and did not check their release date. I just need to explain the discrepancy for a presentation.
John Mayo
Message 11 of 15
Matt.Anderson
John -
Your best bet for the discrepancy would be to look at the EPASWMM release notes and identify the changes that affect hydrology.   (Don't worry about the snark - it hit me about an hour after the first post (which is beyond editable time) that its impossible.)
Send me an email and I should be able to assist.
Product Manager
Autodesk (Innovyze)
Message 12 of 15
Matt.Anderson
To best find the overall difference between SSA  (last new feature was 500104) and the latest version of SWMM (which as of August 2018 is 51013)
https://www.openswmm.org/Compare?v1=SWMM51013&v2=SWMM50014
Product Manager
Autodesk (Innovyze)
Message 13 of 15
robert.dickinsonVR2DF
The current SWMM 5 version is 5.1.015 but there will be an EPASWMM 5.2 soon (2021).
Message 14 of 15
The last ten years of SWMM5 releases and date of the release
Table 1. SWMM History
Release Date Versions Developers FEMA Approval LID Controls
??/??/2021 SWMM 5.1.016 EPA Yes Yes
07/20/2020 SWMM 5.1.015 EPA Yes Yes
02/18/2020 SWMM 5.1.014 EPA Yes Yes
08/09/2018 SWMM 5.1.013 EPA Yes Yes
03/14/2017 SWMM 5.1.012 EPA Yes Yes
08/22/2016 SWMM 5.1.011 EPA Yes Yes
08/20/2015 SWMM 5.1.010 EPA Yes Yes
04/30/2015 SWMM 5.1.009 EPA Yes Yes
04/17/2015 SWMM 5.1.008 EPA Yes Yes
10/09/2014 SWMM 5.1.007 EPA Yes Yes
06/02/2014 SWMM 5.1.006 EPA Yes Yes
03/27/2014 SWMM 5.1.001 EPA Yes Yes
04/21/2011 SWMM 5.0.022 EPA Yes Yes
08/20/2010 SWMM 5.0.019 EPA Yes Yes
Message 15 of 15
orodriguezNRFK3
Community Visitor
Community Visitor
Good afternoon, Autodesk Team,
Can you please confirm which version of EPA SWMM does SSA runs on? I have not been able to locate this is information in the product help or about buttons neither in the release notes in the Autodesk website.
In particular I would like to know on which version of EPA SWMM does SSA 2023 and SSA 2024 run. The reason being is that I am running a test of comparing the same model in SSA 2023 and EPA SWMM 5.2.3 and the results are not converging.
Thank you in advanced.
Omar Rodriguez, PE, CFM
