AutoCad to Carlson 2018
I use Carlson 2018 but my boss and Crew chief have always used AutoCad. The only issue we have to some features don't translate from AutoCad to Carlson or vice versa. My biggest problem is curve information AutoCad to Carlson. Picture for reference. AecDbCurveText (AecCivilBase) should be radius and length respectively
Is there any way to import AutoCad features into Carlson so I don't have to re-enter information constantly?Screenshot (4).png
Kevin.Spear
Sorry your having this issue. First distinction is that you're looking at Civil 3D labels, not AutoCAD text. When in vanilla AutoCAD, there is an object enabler that allows a flavor of AutoCAD that is not Civil 3D to see the Civil 3D objects. Second distinction, you're working in Intellicad so there would not be an object enabler for you.
Are there other options? There is one more - the person who gave this file should set PROXYGRAPHICS to ONE in the file and send it back, then the civil 3d stuff should be visible without the enabler.
Hope this helps!
Kevin
Kevin Spear, PE
