Autocad Scaling Issue
So I've run into a problem the last day or two with Autocad Civil 3D 2019 that I cant seem to figure out how or why its happened.
I have a drawing where we have done our boundary work in a ground coordinate system. We have some reference files that are in a grid system. However when I try an xref the reference file in and tell autocad to scale the reference file up to match using the inverse of the scale factor Autocad gives me an error telling me that I am using an "Invalid Scale Factor. Please enter non-zero numbers" - even though I am very clearly using a scale factor that is greater then 1
If i try and bring the xref in as a block and then scale it up afterwards using the scale command - i get an error saying that I require a numeric distance, second point, or option keyword when I tell it scale the object up using 0,0 as a base point and 1.000264069714405 as my scale factor. (See Command History Below)
Command: SCALE 1 found
Specify base point: 0,0
Specify scale factor or [Copy/Reference]: 1.000264069714405
Requires numeric distance, second point, or option keyword.
Specify scale factor or [Copy/Reference]: *Cancel*
Any idea as to what happened to cause me to suddenly be unable to scale?
