AutoCAD Map Messages
I have never seen this error message before.  The popup in the lower right of the attached image is what I saw when I started Civil 3d just now.  Clicking it brought up the dialog box, which I have also never seen.  As there are clearly hatch patterns in the drawing behind, WTF is happening here?MAPERROR.jpg
I have Civil 3d 2018.3, Autocad 2018.1.2, and Map 3d 2018.0.1 installed.
CADvisers
My guess is that the detail was created using a custom hatch pattern.  And you don't have the path set in the support path settings to read the custom .pat file.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Good thought, but I don't see anything that has changed regarding my paths.  Besides, if Autocad can't find a hatch pattern, it gives a completely different error message, then proceeds to use whatever pattern is available (usually solid).  All of the hatches in use in this simple detail drawing are displayed correctly.
