Autocad Crashes when exploding a block that contains a topo
rosaly.zambrana
rosaly.zambrana
I recently was switched into Civil 3d 2016 and I am not able to retrieve some contours from a block. I was able to do it with Civil 3d 2013 before by exploding the block. Right now, If I do that on Civil 3d 2016, the program freezes.  I have no idea what to do to solve the problem. I will appreciate any help regarding this.
Jay_B
If I insert a tutorial surface dwg as a block and explode it, I'm able to rebuild the surface & Extract Contours from Surface without a crash using C3D 2016 SP2.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Have you tried with different files? I've never had this problem before.
A quick work around, I guess, would be to copy the contours from inside the block editor and paste them in the model space.
rosaly.zambrana
I did all of the above. Thank you anyway.
rosaly.zambrana
I will be doing the C3D 2016 SP2 update. Thank you so much, I will keep you updated.
rosaly.zambrana
Thank you so much, Jay! Problem solved!
