Announcements
Announcements
We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Attach Georeferenced Image
Greatsyd
Message 1 of 17
Greatsyd
Anybody has a faster way of attaching georeferenced images using C3D 2024?
I used "XREF," "attach image" before but this is not working anymore.  Now I change workspace to Planning and Analysis and then insert image.
If I use XREF now, the georeference metadata of the image is not used.
Anybody with a similar problem?
Thank you in advance!
__PRESENT
Replies (16)
Message 2 of 17
MMcCall402
Provided your coordinate system has already been set for your zone you should be able to use MAPIINSERT to bring in the image.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 3 of 17
Greatsyd
Thank you!
Message 4 of 17
Pointdump
Hi David,
If your image's coordinate system doesn't match your drawing's coordinate system, then use Raster Tools IINSERT.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 17
Antonia_NgampoZVBAW
hello here, I have a similar issue
both my image and drawing are in the correct coordinate system, but when i try to attach my image it does not appear at the right place, instead it asks me for the specific coordinates where to place my image ( but i can't know that). since they are both correctly georeferenced, the image should appear at the right place ,isn't it?
Message 6 of 17
EBDBC3D
You're using IINSERT, not XREF right? Does your image have a world file associated with it?
Message 7 of 17
Antonia_NgampoZVBAW
Hello
I usually  just click on this. And yes it has a world file (JGW) associated with it.
Message 8 of 17
Pointdump
Hi Antonia,
"my image it does not appear at the right place"
Let's see what you've got. Please post your drawing and the image.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 17
Greatsyd
Try using "NO" coordinate system on your drawing. Remove the image. Audit - Purge - Save. Then use MAPIINSERT and see what happens.
Message 10 of 17
Antonia_NgampoZVBAW
am not sure i can do that i may try a screen recording.
this is my drawing with its projection
here is the image and its world file
I have this pop up when i try to attach the image
i have opened the JGW file in a bloc note to obtain the coordinates of the image
I pasted it, but still nothing, the image does not appear
Message 11 of 17
Antonia_NgampoZVBAW
sorry, i am not sure i understood
Message 12 of 17
EBDBC3D
Rename the image file and world file. It might not like the period in the file name.
Message 13 of 17
Greatsyd
Maybe I'm wrong but can you can check your "Units?"
From your screenshot I can see that it's in "inches."
I believe France uses meters.
Message 14 of 17
Antonia_NgampoZVBAW
Thanks, I noticed that after and changed to meter, but I still it did not change a thing.
That's still what I get
Message 15 of 17
EBDBC3D
It's not the units - the x,y,z wouldn't be 0 if it was. Did you remove the period in the filenames?
Message 16 of 17
ChicagoLooper
Hi @Antonia_NgampoZVBAW
Decheterie, correct?
Your workflow to insert your image needs to be examined. The jpw (image world file) is not recognized when using MAPIINSRT command.
Your JPW (world file) indicates WHERE your image should be inserted (refer to image on right). Your MAPIINSERT command indicates to insert the image at 0,0 (refer to image on left).
The .jpg and the .jpw must have the exact same name, only the extensions are different.
Both the .jpg and the .jpw must be in the same folder.
Chicagolooper
Message 17 of 17
andrewpuller3811
How long is your file path and file name?
The MAPIINSERT command is not able to handle files when the file path is longer than 128 characters.
You need to keep the file path including the file name to 128 characters or less long for the MAPIINSERT command to see the World File (where it gets the coordinates from).
Also, you should start a new post rather than tagging onto an old post so that if someone provides a solution, you can mark it solved which allows other users to search and find you problem and that it has been solved.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
