Assign coordinate system, using commandline
I have forgotten. Which command can be used to assign a coordination system to a drawing? I remember it was something like; CSASSIGN, ASSIGNCS, or something like these, but I don't exactly remember.
Bijan
Jay_B
Command: MAPCSASSIGN ?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
andrew.schroeder
First set CMDDIA = 0, then issue Command: ADESETCRDSYS or MAPCSASSIGN.  When you're done, switch CMDDIA =1.
If this works for you, please mark it as the solution for others.  Thanks!
Check out my submitted ideas, and vote if you think they'd be useful:
-> Alignment Regions for Station Range-Based Styles in Civil 3D
-> Add Conflict Resolution Options When Pasting One Surface into Another
chriscowgill7373
I've run into an issue when using this method to set the coordinate system. Although the coordinate system displays as the select system, it doesn't seem to actually take to the drawing until you have physically opened the Drawing Settings dialog, viewed the Units and Zones tab, and then closed the dialog.  We ran into a few issues with some of our projects because we didn't catch this when we first instituted this method of swapping our coordinate systems.  I have since removed the commands from our customization files, and we've had to resort back to utilizing the settings dialog.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
cwr-pae
In C3D 2019 the following works as a macro in the tool palette and could be used in a tool bar. With the online maps on it doesn't require anything else to be done and changes the map display to the appropriate zone. It also updates the Zone indicator I have in my status bar instantly [(setvar "MODEmacro" "Zone = $(getvar, CGEOCS)") in acaddoc.lsp] .
^C^Ccmddia;0;ADESETCRDSYS;s;LA83-NF;^Ccmddia;1;regen;
Replace the red text with your coordinate system code of course.
This method unfortunately does the same as the previously suggested one.  In the attached image, the left screen (fig. 1) is using the macro, and the right screen (fig. 2) is using the "old fashioned" method of going to the Settings tab of the Toolspace and opening the drawing settings dialog box. Both are using NAD83 Indiana State Planes, East Zone, US Foot Coordinate System.  As you can see, in fig. 1, the Northing and Easting do NOT match the Grid Northing and Easting, and In fig. 2, they match.  This also effects the Latitude and Longitude coordinate since they are apparently tied to the Grid Northing and Easting.
Like stated before, the points can be fixed by opening the Drawing Settings dialog box, going to the Units and Zone tab and then closing the dialog box.  That however, completely defeats the purpose of having a button or a custom command if I have to open the dialog box anyway.
