Assign a Link target to a point in subassembly composer
khaledCULN8
khaledCULN8
I'm trying to connect point number P25 to Link L26.
is there a way to assign a target to point 25 so it can reach link 25?
see the attached photo
thank you in advance
khaled
KMercier_C3D
To define P25:
  • Delete the P25 that you currently have.
  • Add an Intersection Point (the new P26):
    • Type: Intersection:LinkPointSlope
    • Link: L26
    • Point: P24
    • Slope: 100%
  • Add a Link from L24 to P26
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
lynn_zhang
Hello @khaledCULN8 ,
Just checking to see if your problem has been solved. Did the response from @KMercier_C3D help answer your question? If yes, please click on the "Accept as Solution" button in her reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
khaledCULN8
Dear kati,
first of all, thank you very much for your help.
2nd of all, What is the type of the new point (P26)? Slope and Delta y?
If yes, where to put what you wrote in your post? in the delta Y box?
If yes, it will be like the following
intersection: L26P24100%
and after that add a link.
If I’m wrong, could you please show me exactly what to type? Or you can attach a pkt file with The method that you suggested?
best regards,
khaled
KMercier_C3D
Point P26 is not a plain Point but an "Intersection Point"
Pronouns: She/Her
