Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I have everything needed for plotting of cross sections. Alignment, profile, assembly....
The "Corridor Section Editor" shows everything as it should be. Existing Ground, Final Grade, Labeling, etc...
When "Create Multiple Views" or "Create Section View" only existing Ground shows. All layers are on...
Any ideas..
Have you sampled the corridor? Under group properties, the sections tab has a 'sample more sources' button (top right had corner) open it up and you will be able to add or remove objects to your section views.
In toolspace go Alignments/Centerline Alignments/Sample Line Groups/SLG-1 (or whichever sample line group you're focused on)/Sections then right click on sections and choose Sample More Sources
