Assembly & Corridor Problem
hmoobvue
hmoobvue
I have an existing road with the right side being a superelevation at a lower grade than the left side.
In picture 1, is what i want the cross section to look like.
Picture 1:
In picture 2, this is my current cross section. it is not align at the crown. I used overlaywidenmatchslope1 for the left and overlaymillandlevel1 for the right.
Picture 2:
In picture 3, is the corridor targeting setting. What am i doing wrong?
Picture 3:
Need assistance.
cwr-pae
Check the "use profile options" of the right hand sub in the assembly. I think the minimum clearance and overlay depth have to be set to match the left hand subs overlay depth.
I have this issue frequently when using different overlay subs adjacent to one another.  If you have the newer "OverlayMillLevel1Lane1Side" sub, I find it to be more adaptable to this kind of situation.
hmoobvue
i don't see that subassembly. i'm currently using civil 3d 2013.
tcorey
You're not going to find the "New Rehab Subassemblies" (how long can they keep that name?) in your 2013 Civil 3D.
For those who use 2018-2020 versions of Civil 3D, look for the New Rehab palette of the Tool Palettes dialog. You might need to dig for it - right click at the bottom of the column of tabs, where you see overlapping tab edges. On the dialog, you will see additional tabs , including New Rehab.
Don't forget to put it back when you're done, or you might not see the tabs that are usually at the top of the list.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
cwr-pae
The new rehab subs are also in the catalog if you can't find them in the tool palette.
@hmoobvue you will need to play adjust the minimum clearance to get the right hand lane to line up with the left lane.
