Arrows in cross sections on links to the lower direction of the slope
cyberflow
Advisor Advisor
cyberflow
Is there a way to show the arrows in the cross sections in the direction of the low side of the links ? (See image)
I havent found nothing (See file attached)
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Accepted solutions (3)
RonaldBrañez
You can add labels to the links from the code set style that you assigned to the corredor.
In the corridor properties> codes Tab> edit code set> "Pave" label style
M_Obradovic
Hi cyberflow
In Attached drawing you will find section label percent with arrows.
Cheers Milos
cyberflow
@RonaldBrañez  Thank you, i knew that already
My question is if we can make the arrow dynamic with the direction of the water ?
Frank Freitas
LinkedIn
cyberflow
Thx @M_Obradovic
Let me complete the information for futur users who will search for this :
1) Need to create a "Expression" that calculates the downward grade angle of the arrow
2) Then you simply assign it to the codeset style under the link of the top course
3) Apply and enjoy
Frank Freitas
LinkedIn
