ArcGIS Connector and Pipe Diameters
Civil 2D 2024.3.
The short question is this, "How can I use the ArcGIS Connector to import pipes with the proper diameter?"
I have a dataset in ArcGIS Online with some pipes. I use the ArcGIS Connector and mapped the pipe properties accordingly. The pipes' inside diameter properties in ArcGIS vary from 100mm to 1700mm. The pipes import into Civil 3D, but all their diameters are 100mm, as per the default setting in the image below.
Interestingly, after import the property set data shows the diameter properly.
Thanks in advance.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Link copied
