ANZ Country Kit 2024 causes fatal errors
Hi all,
I was excited about upgrading to 2024 and installing the ANZ Country Kit after having training on it. Unfortunately, it produces repeatable fatal errors in certain, and a few uncertain, situations.
After upgrading (clean install) my pc to C3D 2024 with the ANZ Country Kit, it would produce a fatal error when opening the acad.dwt template that was installed with it. Troubleshooting found that it would open with AutoCad fine.
Using the Sheet Set Manager, creating a new sheet set then trying to open that layout, also produced a fatal error.
A few dwg files from outside the company would also produce this error.
Upgraded a 2nd pc (clean install) the same 2024 build and ANZ Country Kit, same repeatable result with the errors.
A 2nd clean install without the Country Kit did not have these errors.
Checked another pc that was upgraded earlier, same result.
This is more of a Public Service Announcement than anything in case someone searches for the same thing I did, but has anyone else in Aus/NZ experienced the same thing?
TIA
