Alignment Station Offset Label Doesn't Appear in Viewport
C3D 2019.2 Win10
I created a simple station/offset label. The drawing's scale is set to 1:40 and it was when i created the label style. In viewports at 1:40 the label appears fine. In a detail viewport with a scale of 1:5 the labels don't appear. I can't figure out why.
The labels are on a thawed layer in the viewport. They are alongside several annotative multileaders that are on the same layer and the multileaders appear. In the label composer dialog, the label contents are on Layer 0 (general tab).
I created a simple drawing to attach to this post for examination - and in that drawing, with viewports set at 1:40 & 1:5, the label works as expected. So it seems particular to my working drawing.
The drawing has alignments, view frames, and several sheet tabs generated from the view frames. It'd be messy to get everything into a new dwg. It originated from Microstation elements converted to dwg objects. I had issues with *all* of the Cogo_Points producing errors on every recover/audit but after deleting the points and re-importing them I get no more errors. I purged unused styles, then did a regular PURGE. Now, AUDIT/RECOVER reveal no errors.
Any ideas on how to get my sta/off labels to show up in a 1:5 viewport?
I'd rather not re-create the dwg. Is there something I can check before I try too get it all into a new dwg?
See attached dwg. There should be no data references or xreferences. The dwg was saved at the suspect labels - magenta on C-WATR-TEXT-0004. The detail viewport in which they do not appear is on layout W-2, bottom left. There are pressure networks in the dwg - I don't know if it will bomb because of missing parts lists or not.
I hope it's just some simple thing I overlooked.
wfberry
It appears that the layer is frozen in the Viewport.
Bill
user181
Your alignment is on layer 0 and layer 0 is frozen in the viewport so the labels are not showing.  Thaw layer 0 in the viewport or change the layer the alignment is on.
doh! thank you!
