ALIGNMENT SETTING OUT TABLE ISSUE
Domziman
Domziman
Hi Guys, In our company we have our Alignment Setting out table and its working without any issues on Alignment with no arcs, but as soon as you have a straight alignment the Setting out table is not correct. For some reason if you create your alignment labels for the table it does not want to read the end an a straight alignment. is there a way around this?
Civil 3D Certified Professional
tcorey
Can you post your drawing and the examples of the report?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Kyle-L
You will need to create a unique setting out table style for straight alignments.
Basically you will need to create a line label that says something like "Start End", then in the table style you add the start and end coordinates to the "Value:Line" row for the columns that you have the coordinates in.
You can see this in action in the screenshot below. I hope it makes sense.
Domziman
I have done what you said but for some reason it keeps splitting the the start and end and keep giving them the same easting and northing.
Domziman
i found the problem, it was in the actual alignment label. this is sorted now thanks
