Alignment not plotting correctly
I'm using C3D 2017. I have a curved Alignment in my drawing with multiple viewports. In the drawing, both in PS and MS, the alignment is displaying properly. But when I go to print the drawing, the alignment line/curve seems to be shifting but the labels and tick marks are staying in the correct place.
Has anyone else had this problem and/or have any recommendations on how to fix this issue?
I attached two images. One is a screenshot from C3D showing how the alignment looks and the second of how that area is plotting.
Mike.M.Carlson
Hi-
Is that 2nd image a PDF plot?  I assume you're current with your C3D17 and ACAD service packs?  I've seen this with rotated UCS at times, but can regen to resolve it.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Yes, the 2nd image is a PDF plot but the issue exists if I plot to PDF or directly to a printer or plotter.
Yes, we're current on all of the Service Packs and updates for 2017.
The view port does have a rotated UCS. But in C3D everything looks correctly, it only has an issue when plotting. I had a co-worker open the drawing and the same issue happened to them.
