Alignment IP label
Alignment IP label
itzhakLFGFA
Alignment IP label
itzhakLFGFA
Hello everyone.
I'm trying to create an Alignment PI label that will count up +1 (Something like that-PI1-PI2-PI3).
Can anyone tell me what the Expression should look like?
MMcCall402
There's an alignment label specifically for point of intersections.
One of the properties of the the alignment PI that can be labeled is the Alignment PI Index. This is a sequential numbering of the alignment PI's.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
jakub.siwiec
Autodesk Support
Autodesk Support
Hi @itzhakLFGFA,
thanks for posting! @MMcCall402 thank you for helping out!
@itzhakLFGFAcould you tell me if solution provided by @MMcCall402 is sufficient for you, or do you need additional explanation?
If @MMcCall402  managed to answer your question press the Accept as Solution button on his answer please. This will help other users to find solution much faster. Thank you in advance.
Best regards,
Jakub Siwiec
Jakub Siwiec
Global Product Support
My Screencasts | Troubleshooting
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @itzhakLFGFA
I’ve just accepted the response to your post (@ as a solution with the understanding that it is the correct answer. If this response did not work as an answer, please reply so that I can unmark the solution, and we can continue the conversation.
No action is required if this response did work as an answer, however I wanted to point out that if the opportunity arises again you can also click on the ‘Accept as Solution’ button if/when relevant so that others can more easily benefit from the information.
Please feel free to let me know if you have any questions or concerns!
Artur Kosakowski
