Alignment grid view
Alignment grid view
abiti.gezahegn
Alignment grid view
abiti.gezahegn
Hello there, why is the PI station value from "Alignment grid view" and model space different (See the pic attached)? Is there a way to make sure which one is correct? In addition, why is this even happening?
rl_jackson
That almost appears to be reading something other than the PI of the curve, but something to do with a spiral. Is that curve part of a spiral?
Rick Jackson
Survey CAD Technician VI
abiti.gezahegn
Yes, i used spiral-curve-spiral method.
wfberry
There is probably a logical reason behind what you posted, but without the dwg it will probably be difficult to get to the bottom of this.
Bill
abiti.gezahegn
Here's the drawing (Civil 3D file).
wfberry
I am confident that the P.I.s as labeled in your drawing are correct.  The P.I. Stations that are in question are calculated by using the station of the SC then adding the tangent of the circular curve and you get the Station that is in the chart.
What Rick had relayed, BTW.
Bill
abiti.gezahegn
Thanks Bill; that made my day.
