Alignment curves add PI
Ingrid91
Ingrid91
So I have taken over a model that someone else has created. In it there is an alignment made entirely out of curves.
I need to add an element (another curve) between the curves but the program will not allow me to "Add PI" or "Break apart PI".
Am I missing something?
ecfernandez
Hi @Ingrid91, a few screenshots or a sample file could help to understand the alignment configuration. Could you please share more information?
Regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
nkiakas
Hi @Ingrid91
If you want to add a curve no need to add PI.
Select your alignment and then click on geometry editor
On the geometry editor, you have several ways to add curves.
Regards
J-Porter
Sounds like you have a reverse curve.  You need to create an alignment from the existing alignment leaving out a section where the two meet.  Then you can manually add in a line and PI info.   In the image below I have the original alignment on the left and the one I created from it moved over to the right.  As you can see, I left out the section where they meet. To accomplish this, I followed these steps:
Create a new alignment from the existing alignment, specifying the start and end points of the portion you want to isolate.
  • Go to "Alignment" > "Create Alignment from Existing Alignment".
  • Select the alignment you want to use as a starting point.
  • Select the start and end split points and hit "F" (Finish).
  • Name your new alignment.
Ingrid91
This is the closest to a solution that would work, based off of my problem.
It is strange though, that it should be difficult to add elements in an existing alignment without having to create a whole other alignment or delete an element...
J-Porter
It's because reverse curves are not easy to deal with.  I know it's a long workaround solution, but that's all I can think of at the time.
