Ran into a strange bug, and wondering if anyone has a way to resolve it.
The issue is that there is a scaled up version of the alignment that is glued to a certain place relative to the viewport. There are also 2 view cubes for some reason.
Redraw all and regen all did not help. Restarting C3D did not help.
Here it what I was doing immediately prior to the bug occuring:
1. I referenced a data shortcut alignment into the drawing. The same data shortcut was already in the drawing, but I needed another copy so I could promote one and keep the other dynamic.
2. I added a profile of the EG surface along the freshly promoted alignment.
3. I attempted using the drive feature. While in drive, I navigated around a little bit and ended up getting lost so i quit out of the tool.
4. After quitting out of the tool, this bug was present.
Anyone seen this before and know a good path forward?
-Camden
