Can someone explain what is the difference between AEC and AECC object and what they are actually.
Ok but which are aec and which aecc?
I would think that if you opened up a civil drawing with vanilla AutoCad you could tell quite quickly. Just select a few objects and note what Properties Dialog box "says".
Bill
I just to read something more in detail about this objects not only what autocad return in answer
They are all custom objects created by Autodesk for those respective disciplines. Here's a link to the latest (C3D 2012) COM API which includes most AECC objects (some have been added after C3D 2012):
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/civil_om.htm
As for the AEC objects, you'd have to look at the Architectural API.
