AEC rail elevation
AEC rail elevation
itzhakLFGFA
AEC rail elevation
itzhakLFGFA
Hello to all the experts.
Today I used for the first time the 'RAIL' command to place a railing on a retaining wall.
The railing enters the drawing at elevation 0.
Is it possible and how to set the rail elevation from a profile or surface?
Thanks.
Udo_Huebner
RAIL is a command from AutoCAD Architecture. But it is also available in Civil 3D because of the common AEC libraries.
You can anchor the rail to AutoCAD and AutoCAD Architecture objects, but not directly to Civil 3D objects (surfaces, corridors...) If you convert the Civil surface to a SOLID > MASSELEMENT, you should be able to anchor the rail to the resulting Masselement.
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
Gruß Udo Hübner (CAD-Huebner)
Udo_Huebner
The create a Railing use
Command: Railing
To edit the Railing Style use
Command: RailingStyleEdit
To create a Masselement from 3D Solid use
Command: MassElementConvert
To anchor the Railing to the MassElement use
Command: RailingAnchorToObjects
itzhakLFGFA
Thank you for your response.
