Advice on workflow for Land survey process for a student.
Hi all,
I wonder if you would help point me in the right direction. Let me describe my workflow so far and what im finding a little tricky;
  • I Insert a georef orthomosaic with GPC's (I use mapiinsert to get this into C3D)
  • Create a surface from a DEM
  • Create a viewport and add a title block.
I'm all set to start drawing, however the student version i have doesn't seem to have all of the symbols so i may need to freehand some of them, Hedges for instance.
Here is what i think the next steps would be , please feel free to guide me.
I intend to use pline to trace the buildings and fences and boundaries. (all on new layers for styling later)
Use the small symbol set i have available for the trees.
Where the trees and shrubs are overlapping i shall just pline a foliage area.
General spot elevation grid over the area
Contours on from the surface and have the elevations running along them
Identify all utilities and place relevant symbols
Create a legend from the symbols used
This would give me a standard topography map i believe. I would then add the scale and it should be ready unless i'm mistaken?
How does this look for someone trying to develop a workflow who is very new to civil 3D and Autocad.
Any help/advice is greatly appreciated.
Best
Chris
tcorey
REVCLOUD makes a nice foliage outline. You have lots of options to control the look.
North Arrow.
Vicinity Map
Property boundaries with bearing/distance labeling.
Surveyor's control points with surveyor notes.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Thank you very much.
dbinkney
The only thing I see missing are:
  • Source notes, including image and survey data (who collected the data, and when)
  • Horizontal and Vertical datums noted, with units
  • (this will be helpful for the future) a Drawing tag, which will list the drawing file name and location, the user who printed it, and date/time.  If  you start making lots of drawings, this becomes invaluable.
Good luck!
