Is it possible an entire pipe network could be adjusted at once? I have a pipe network that somehow got accidentally edited all at once. But not just moved vertically up or down. What happened is that the slopes of all the pipes in the network changed to 1%, and also the beginning and end elevations got thrown off vertically by about 30 feet in the process. The vertical displacement varies slightly (no pattern to it that I see), but the slope of all the pipes is now 1.0% whereas the slopes varied before; some were 0.5% and others 2.0% or whatever. How is this possible that a blanket changed happened like that all at once?
Link copied
