Adding multiple labels (General, Spot elevation,...) by selecting objects
cwr001
Message 1 of 19
cwr001
this one is not a deal breaker but it would be nice to have:
Certain labels (the most important ones for me are "General" and "Spot Elevation on Surface") require the user to click on the desired spot one by one for each label.
I was wondering if there's a way to add more than one label by selecting objects (idealy: points).
(I know about "AddSpotElevLabelsOnGrid" but I don't want a grid but only specific points)
The workflow I'm looking for would be:
AddNoteLabel or AddSurfaceSpotElevLabel --> Select objects (points)--> Multiple labels are created
I could go the label COGO-points route but COGO points unfortunately don't allow reference texts.
Is there a way or maybe existing code to achieve this?
Thanks and best regards!
Replies (18)
Message 2 of 19
rkmcswain
If you have one surface, the following lisp should be close to what you want, except it's currently set up to work with POINT entities. If you have multiple surfaces, the prompting is a little different and will require some editing.
(defun c:foo ( / sset k m i )
  (setq sset (ssget '((0 . "POINT"))) i 0)
  (repeat (sslength sset)
    (setq k (ssname sset i))
    (setq m (cdr (assoc 10 (entget k))))
    (vl-cmdf "._ADDSURFACESPOTELEVLABEL" m "")
    (setq i (1+ i))
  (princ)
Message 3 of 19
TerryDotson
If you were to consider third party add-ons, DotSoft's C3DTools can add spot elevations on a selection set of objects.  For linear objects like polylines/featurelines you can specify the interval.  Even contains a special alignment option to specify station range/interval and multiple offsets (-10,0,10 etc).
Message 4 of 19
cwr001
Thanks a lot - this works exactly how I envisioned it!
What would be the way to go about if I wanted the lisp to work if multiple surfaces are present?
Can you point me in the right direction - would this pseudo code approach be viable here?
- Get a list of points objects
- For each point:
---> _AddSurfaceSpotElevLabel
---> Press Enter twice (I don't really care about which surface is used, I can assign them later with select similar)
---> Paste point coordinate from my list
Does it work like this or do I have to opress the whole dialog with some deeper API-stuff?
@TerryDotson: Thanks for pointing out that possibility - I'll have a look! 🙂
Message 5 of 19
knuwan
Hi!
Can you kindly tell me how to run this LSP? I loaded it using "Load application" under "Manage".but dont know how to make it work to select the objects as you shown on your video.
Thanks.
/Krish
Message 6 of 19
cwr001
Sure thing:
* Copy the whole code from the codeblock and past  it into an empty *.txt-document. Rename that document to something like "MultipleLablesByPointSelection.lsp" (Make sure that the ending *.txt is changed to *.lsp).
* Start Autocad and run the command "APPLOAD". Select the just created Lisp-File and choose "Load".
* You can run the lisp by typing "FOO".
Note: "Foo" and "Bar" are common placeholders for code creation. If you want a more substantial command to start the lisp, you can just rename "FOO" in the *.lsp-file to something of your choice.
Message 7 of 19
rkmcswain
@knuwan -- In its current form, you load the lisp code, then the type in command would be "FOO". You can rename that before loading the file if desired.
Message 8 of 19
knuwan
Yes the "FOO" command worked.but it doesnt detect my blocks.
Message 9 of 19
knuwan
Message 10 of 19
knuwan
I even tried placing circles etc.but nothing get selected.
Message 11 of 19
rkmcswain
@knuwan - correct, the lisp code is filtering out every entity type except "POINT"
Message 12 of 19
knuwan
can you come up with a update that can be used in my situation?
Message 13 of 19
knuwan
you know what, I extracted points from the surface and ran the LISP wow!
Message 14 of 19
rkmcswain
@knuwan - feel free to edit the code to your needs.
Change "POINT" to whatever entity type you want. Some entity types may not work as expected, so experiment around.
(0 . "POINT")
Message 15 of 19
knuwan
OK! Thank you very much for the trick!
Message 16 of 19
tony1978
Our company has two surface labels apps that allows you to automatic spot label all selected intersecting feature lines or polylines with a drawing. This is great for spot grading large amounts of concreate slabs for gas stations or airports projects. The other app allows the user to select a feature line and label all the vertices. A good example is selecting the gutter or top of curb feature line for a commercial property. Checkout or help videos below and also our suite of apps on the Autodesk App Store.  In one 3 acre commercial project my grading plan had 247 spot labels. With our app I was able to select 4 gutter line feature lines and 240 labels appear. Yes are they are dynamic to the surface. So if the feature line or polyline moves you can click the update bottom and the surface updates.  This also worked good for subdivision spot grading swales and pads.
CCLS Tools - YouTube Channel
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
Message 17 of 19
rymen_kyro
Since the lisp need "Point" entities, i converted cogo points into cad blocks then explode to get the points entities but lisp tells me that those points are invalid points. Can you help me please? i tried to edit the lisp and put "cogo points" instead of "points", but still not working.
Message 18 of 19
cwitzel5NL5H
LIST a Civil3d point, to find the type.  Should be something like AECC_COGO_POINT or something like that.  (Sorry in the middle of a large operation so I can't just tell you)
Conan Witzel
Herrera Inc
Message 19 of 19
darshjalal2
Good day,
For anyone needs this code for generating spot elevation labels from points in Civil 3d, use the attached lisp.
Regards.
