Adding labels to points from DXF / Data Imported from Leica Total Station
david_lewisXXPBG
david_lewisXXPBG
Hi all,
I used a Leica Icon Total station at work for construction surveying. I've been exporting the files from the total station as DXF.
When I open in AutoCAD the labels appear as they are in the file I've provided.
I can't seem to add / change the labels to show the correct elevation as I have shifted the data to a different height.
I've tried importing the points through a CSV and that works to be able to add to points groups, but then I lose the layers which are importing for my work.
Thanks.
Pointdump
Hi David,
Welcome to the Autodesk Forums.
When you import points by CSV you can set the layer either in a Point Group or better yet by Description Keys.
You can add or subtract to the elevation of your points in the Point Editor. Right-click on the elevation and choose "Datum".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
