Adding a profile to a pressure network to represent the pipe invert levels in a profile view
I am at the moment working on a small section of pressure pipe. I used the Create Pressure Pipe Network from Object command to create a pressure network in the plan view. I then create a Profile View using the Pipe Run Profile command in the Pressure Network Plan Layout contextural ribbon. Following this method I was able to produce a Profile View displaying my pressure pipe network. In this profile view I am able to adjust/override the pipe elevations using the profile that civil3d created during the process. However, I need to be able to extract the pipe invert levels and display them in a Data Band. The profile that was created by Civil3d sits on the top (crown) of the pipe. I am able to copy this profile and set it down by the diameter of the pressure pipe to produce an Invert Profile. Then I can use this new (copied) profile to give me invert data for my Pipe Invert data band. However, using this method the invert profile is NOT associated to the Pressure Pipe or its Profile. This means that it does not update automatically when I make further elevation adjustments to my pressure pipe. Is there a correct way to produce a second profile that is dynamically linked to the first profile in a Pressure Pipe Network?
I am using civil3d 2024
