I forgot an my OSNAPZ was set to 0. I connected a bunch of points. I checked the lines and they all have Z=0. is there way to add the Z values of the points connected to the lines???? Or do I need to redraw them after changing OSNAPZ to 1?
If you only have a few you might as well recreate them. If you post your drawing I'll use C3Dtools Figure Snap tool to set the elevations to the nearest CogoPoint (within a specified tolerance).
If you have lot of them you can follow this method.
Create a surface from the points.
Add the lines as breaklines with proximity.
Then use insert breaklines to drawing option.
It will extract those breaklines as 3D polylines.
