Add line tables, General Line Label Tag by using Line between two points
jefflambert9091
Advisor Advisor
jefflambert9091
Well I think I just found a little quirk with line tables.
I had added a general line label Tag using the “line between 2 points”.
When I went to make my table by selecting the general style, it does not show up. If I use the selection box and pick it manually it works.
In table creation, I like to select the styles and then in the selection rule use add existing and new. This way leaves me flexibility to add/edit/remove Tags keeping my line table dynamic.
I hope I am just missing something, but I guess I shouldn’t be surprised since I’m not picking a line and just using between two points, but I thought it would work. It will even renumber the tag. I tried in 2018 as well.
Jeff
Civil 3D 2024
BushW
Hi @jefflambert9091
I reviewed the add line table, general labels using the "line between 2 points" command in both Civil 3D 2017-18 and I was not able to reproduce what you explained in your post. Are you missing the general label styles below?
Here is a video below showing the steps, I took to produce a line table using the "line between 2 points" command. Hopefully, this helps you see if your the process is correct.
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit. Here to help and thank you for doing so.
Wendell Bush
Civil Infrastructure Technical Support Specialist
Jeff_M
@BushW, Wendall, I think you missed the part about using the Add existing and new option. When you use this with option and have labels on a line, those labels will be automatically selected when creating the table...i.e., no need to select them manually in the drawing. When you have the same style labeling between 2 points, those labels will not be found automatically and you must manually select them. This is what Jeff is wanting to avoid. Plus, when you add a new label to a line, it will automatically get added to an existing table (when that existing and new option was used), whereas a new label between 2 points will not be added to an existing table.
Jeff_M, also a frequent Swamper
jefflambert9091
Jeff_M you are correct. Well put.
Jeff
Civil 3D 2024
BushW
Hi @Jeff_M
Thanks Jeff for catching that. My misunderstanding on the issue.
I will go back and review this issue again.
Thanks for your help!
Wendell Bush
htls69
any resolution to this?
Allen Robberson
Credit where credit is due! Give kudos or accept as solution whenever you can.
