I'm not sure if this is an issue with a particular label style or what the issue is.
I have a C3D alignment with a label set I created for it that displays PI station and deflection angle. Text is just PI XXX+XX XX°, so just the station value followed by an angle value (rounded to the nearest degree). Currently I have the anchor point set as feature and the anchor point is the middle center of the text (we had a request to turn the labels into attributed shapefile points).
When I do Add labels, multiple point of intersection, select this label style and select the alignment, it does not add labels to all of the POI's on the alignment, only some (if I do just "point of intersection" it will add labels individually if I click near the POI's that are missing labels). I don't know why it's doing this because there is another label style loaded in these drawings by default that displays PI deflection angle in degrees-minutes-seconds, and if you select THAT label style, add labels, multiple point of intersection, it DOES add those at every single POI.
I just noticed the PI-DA angle label style is shown in the add labels dialog box under "Tangent intersection label style" whereas the DA only label is under "Point of intersection label style."
Does anyone know what is causing these to not add correctly?
