Add grade to multiple section views
arpenteur
arpenteur
I just created Multiple Section Views.  The only info that I don't see is the grade (slope percentage), how do I make this possible, please.
Thanks...
cwr-pae
Select a section view. Right click and select 'section view group properties' (or find it in the ribbon) to open the dialog box. On the section tab on the row for the the section you want to label, select the ,Edit..> button under the "Label Set' heading. Add or create a label set for the section similar to alignment and profile label set and apply.
arpenteur
Great, it's working.
Thanks...
