ADA Curb Ramp Workflow
My current workflow for creating curb ramp designs feels a bit dated. I'm curious how others are doing it, hoping to steal some knowledge. Let me say that we're using C3D 2015, about to upgrade to 2019, so we're obviously missing out on some new features.
So here's the jist of what I do: I create an alignment at the gutter flow line, extending 5' past the curb return in both directions to sample any relevant surfaces (I don't necessarily like this - having an alignment start artificially early just to sample surfaces, makes it confusing on plan) to get an idea of incoming and outgoing gutter grades.
I then create two profiles, one for gutter flow line (FL) and one for top of curb (TC), run a custom assembly on the FL targeting the TC profile with the curb face to adjust curb reveal. This step is part of my workflow because in the past (working in development) I was required to show these profiles on plan. Now I'm not, so I'm debating whether or not feature lines would suffice here.
Assuming the horizontal line work is already drawn, I copy in those lines and convert them to feature lines to define the sidewalk ramp leading up and out behind the curb. Historically, I would enter feature line elevations where they attach to the corridor at the back of curb manually every time the FL profile changes. Now, if I were going to stick with this workflow, I'd probably extract a dynamic feature line from the corridor at the back of curb and make sure it's in the same site as the feature lines defining the sidewalk portion. Especially with the new feature line priority tools, this should in theory work well and reduce the margin for error.
Finally, I would create a surface (single surface - add feature lines to corridor surface - as to allow triangulation between feature lines and corridor), data shortcut it out and label that for my plans.
This workflow was developed for new construction development, for use in something like a subdivision, where the entire project could be a single corridor model. Now, I have no requirement to show profiles on plan, and many projects are simply curb ramp replacement projects so this workflow seems like overkill.
A few options I'm considering are: feature lines defining the new curb FL and TC instead of corridor, and labeling feature lines directly instead of the surface. This would require the design elements (feature lines) be in the same DWG as the layouts, or at least XREF'd in. Neither of which are currently part of our standard workflow.
To wrap it up, I give spot elevations at all locations and northing/easting table for the FL alignment. This should give a contractor enough to build these things to ADA standards (assuming I didn't leave anything out of this write up) though I argue that we give them too much information with all of the spot elevations - grades should suffice and accommodate construction tolerances.
Sorry for the long winded description but I want you all to pick my workflow apart, and have a hearty discussion on how to approach these things in various design scenarios. What do you guys do to get these designs out to bid, and what new tools do you use to make these designs easier (dynamically linked feature lines, feature line prioritization)?
