I've highlighted a notification below which reads: "A horizontal geometry change affected this element. Make sure this element is still valid."
How do I turn these notifications off? Very annoying.
Solved by neilyj666. Go to Solution.
I think when you select the profile the contextual ribbon has the option to dismiss individual or all notifications.
I don't know if they can be turned off globally but I'd leave them on and use the method I outlined
There is a way to toggle off that notification.
Follow these steps:
OPTION-AEC EDITOR (last tab)- uncheck drafting in Solution Tips box.
I found this solution from this blog: https://blogs.rand.com/civil/2017/07/civil-3d-2018-the-orange-circle-with-an-i-and-how-to-disable-it...
Edit the profile properties, and go to the Profile Locking tab. Uncheck the Notify which entities are affected checkbox to get rid of the notification symbol on your profile.
You'll have to do this for all existing profiles, if you don't want them to show up anymore. If you want to remove that option from all future profiles you make, you'll need to change the command settings:
