Civil 3D Forum
A horizontal geometry change notification
3 REPLIES 3
RCWisehart
5693 Views, 3 Replies
I've highlighted a notification below which reads: "A horizontal geometry change affected this element. Make sure this element is still valid."
How do I turn these notifications off? Very annoying.
3 REPLIES 3
neilyj666
in reply to: RCWisehart
I think when you select the profile the contextual ribbon has the option to dismiss individual or all notifications.
I don't know if they can be turned off globally but I'd leave them on and use the method I outlined
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
There is a way to toggle off that notification.
Follow these steps:
OPTION-AEC EDITOR (last tab)- uncheck drafting in Solution Tips box.
I found this solution from this blog: https://blogs.rand.com/civil/2017/07/civil-3d-2018-the-orange-circle-with-an-i-and-how-to-disable-it...
AdammReilly
Edit the profile properties, and go to the Profile Locking tab. Uncheck the Notify which entities are affected checkbox to get rid of the notification symbol on your profile.
You'll have to do this for all existing profiles, if you don't want them to show up anymore. If you want to remove that option from all future profiles you make, you'll need to change the command settings:
Adam Reilly
Dell Precision 55400
Windows 10 Pro
Intel Xeon E-2276M 2.80GHz, 64bit
NVidia Quadro T2000 Mobile/Max-Q
LinkedIn | Twitter
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Rail Community
