Civil 3D Forum
3D solids not projecting in section view as crossings
4 REPLIES 4
niranjan.jawaleMXG5Z
252 Views, 4 Replies
I want to project 3D Solid to section view as a crossing not as a projection, but when I tick the crossing box it is not showing the solid into cross-section view. There are some solids that behaves like this, other solids are projecting normally. I also try to change the style for crossings but it did not work.
My sample line is also going through the 3d solid, but not showing the cross-section
Labels (3)
4 REPLIES 4
Attach your file to discover the problem.
Hello, here is the DWG file. I just want the crossing section. When I tick the box for projection then the solid is visible. But I need the cut section of that solid only.
Thank You.
Thank You.
Here we go,
Just do these steps:
- Select your section view> Section view properties
- Projections and Crossings tab
- Make check same picture below
- Done
Rail Community
