2D Road Markings onto Surface
RupinderWilkhu
RupinderWilkhu
Greetings,
Anyone got any advise on how to 'drape' Road Markings (at 2D elevation 0) onto a Surface.
The Road Markings are a combination of blocks, hatches, text and polylines.
ecfernandez
Hi there, you can convert all your markings to individual blocks and then use the "Elevation from surface" tool to pull them onto the surface.
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
VincentSheehan
Maybe setup a Feature Line style as road markings. As you create the Feature Line, assign it to the surface. Explode it to a 3D poly if needed.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Ann-Marie_Valois
How about this workflow?
1- Use infraworks to create your striping on the surface
Create an FDO database connection in Map 3D or Civil 3D to the InfraWorks model sqlite database to connect to the coverage data
  • Extract the coverage data to polygon
  • Edit the polygons in Civil 3D or Map 3D
https://youtu.be/RSO1heQujys
ecfernandez
Thanks for sharing @Ann-Marie_Valois, that is a really good option. Best regards!
Camilo Fernández
LinkedIn
RupinderWilkhu
Many thanks to all those who responded. much appreciated.
We went with the option to convert the elements to blocks and then move to surface.
